Threads: 80
Thanks Given: 25
Hi , can anyone help urgently, I am at Plymouth and ready to board ferry tomorow 8.00am BUT the stick on deflectors for my lights , I have no idea where to put them......Will standard deflectors on lights fit , and where do they go?
Cheers
Pete
2010 artic silver VTR with EXTRAS.......
unny:
Threads: 80
Thanks Given: 25
any other suggestions, anyone done this to their mk3. ???
unny:
Threads: 32
Thanks Given: 24
I can show you on a Mk 2 if that's any use?
Threads: 80
Thanks Given: 25
are lights similar? thanks if you can may help
unny:
Threads: 32
Thanks Given: 24
22-10-2011, 08:55 PM
(This post was last modified: 22-10-2011, 09:21 PM by Coco.)
They are different, but may give you at least an idea.
07.00 tomorrow any good?
Pete,
PM sent
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• pch
Threads: 15
Thanks Given: 46
5
23-10-2011, 01:12 PM
(This post was last modified: 23-10-2011, 01:13 PM by Opensauce.)
You don't need deflectors on Mk3 headlights. I have a letter from Citroen UK stating this. Enjoy your trip.
Threads: 17
Thanks Received: 14 in 10 posts
Thanks Given: 6
23-10-2011, 03:21 PM
(This post was last modified: 23-10-2011, 03:21 PM by colinh.)
Turn on the headlights - dip beam -and crawl around in the gutter to find the beams that shine furthest on the left.
Get an assistant to mask the lens with a fingers or two, to find out where these beams come from and apply black tape.
Or just turn the lamp adjusters well down.
UK LAW says you must'nt dazzle, it doesn't say owt about deflectors.
'98 D 800 van
Threads: 15
Thanks Given: 46
5
I never used deflectors on my mk2 or my current mk3 for reason that nobody ever flashed me up on dark French N roads. The beams are fairly symmetric with only 2 small points of light to the left. The old type glass headlamps with prismatic lenses dipped sharply to left & it was easy to see where to stick deflectors or tape(I always used tape).
With the modern clear plastic lenses its not really obvious where you do stick deflectors & I don't think they need them. I emailed Citroen Uk & they confirmed they are not needed for the Mk3 at least.
Threads: 80
Thanks Given: 25
coco:::::what a star , met me at the dock!!!thanks;;;;
unny:
