Threads: 3
Hi all.
My steering has started juddering whilst turning. Was told pump and pipes looked ok. Any clues to what it could be???
Threads: 20
Thanks Given: 2,126
18
How old is it? Check the PAS fluid colour,it should be bright red.If it's dark red/brown,drain the system & refill.You should get an improvement.
Strawberry flavoured windows
Threads: 23
Thanks Received: 497 in 454 posts
Thanks Given: 48
27
03-03-2017, 09:26 PM
(This post was last modified: 05-03-2017, 04:40 PM by Jed Clampit.)
Hello Big Val welcome to the forum what is the date did you buy the berlingo might sill be under some sort of warranty did you buy it from a Citroen dealer they give you 12 months warranty.
Threads: 58
Thanks Received: 691 in 589 posts
Thanks Given: 177
44
04-03-2017, 12:32 PM
(This post was last modified: 04-03-2017, 12:33 PM by geoff.)
Do what Ron says unless the car is under warranty.
Serieal Berlingo owner
