Threads: 5
Thanks Given: 1
hy everybody
My little van has a suspected head gasket temp, gauge goes up and down while driving but never boils over. I'm no mechanic i did a head gasket test and it's showing negative so any sugestion and help from someone please!!! Many thanks
Threads: 67
Thanks Given: 237
50
.... up and from what and too ???
Serieal Berlingo owner
Threads: 4
Mines just started doing this after replacing head gasket, any suggestions would be great! going up and down between 90 & 100
Threads: 61
Thanks Given: 234
29
what engine is that? Petrol/Diesel?
Threads: 5
Thanks Given: 4
21
Might be worth bleeding the system and also the thermostat itself might be sticking?
Threads: 20
Thanks Received: 17 in 14 posts
Thanks Given: 31
Just going by what we did years ago when we had no money ....
If the temp rises and when hot then noticably drops but then stays even your thermostat is working ok.
If it stays hot with a little or no drop your thermostat may be sticking and either needs replacing or throwing away. Years ago we threw them out as it was cheaper!
The car will not complain. I was told this may cause an issue in the winter, just mevr discovered what as the car still ran fine just the heater took a lot longer to get going.
You can whip the thermostat out, and boil it up in a pan of water. If it is ok you will see it open when hot.
Unless cars have moved on and all the above no longer applies! Who knows?
It's a 2001 1.9d with 322,500 k on the clock.
Thanks Given: 1
What about coolant temperature sensor?
Threads: 25
Thanks Received: 27 in 26 posts
Thanks Given: 16
6
I believe that taking the 'stat out can have the opposite effect as the coolant circulates too quickly and doesn't transfer heat from the engine as effectively...??
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Threads: 67
Thanks Given: 237
50
08-07-2021, 09:50 AM
(This post was last modified: 08-07-2021, 09:50 AM by geoff.)
Don't remove and leave out the thermostat please as you will likely compromise cooling at the cylinder head causing local overheating and probable head gasket failure.
No further info from Rui ?? anyway it is possible that all is well and normal.
Robbie, it gets confusing with folks jumping onto someone elses Topic always better to start on specific to yourself.
Robbie I'd be looking at bleeding the system ( there are specific bleed points ) can you tell us if the temp problem was present before the head gasket failure or is it since then ?
