Threads: 3
I have just fitted a new clutch cable to the van however it doesn't seam to have the auto adjustment thing around it like the other ones I have read about on the internet. It works fine but you have to push the pedal right to to the floor to get it to work. Any one know how its adjusted?
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
The early ones had an adjuster build into the cable , the later ones have a automatic adjuster in the pedal.
Then there are 1.6s with a hydraulic system.
Which one have you got. ?
Check for the auto adjuster on the pedal, the cable for that doesn't have the adjuster build in.
If not check the proper way of adjusting the adjuster on the cable.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 67
Thanks Given: 237
50
^^^ Isn't that the auto adjuster in the centre of the cable - the thick black bit ?
Looks like the one on my 1.9d which had auto adjuster
Serieal Berlingo owner
