Threads: 8
Thanks Received: 1 in 1 posts
Thanks Given: 3
Do you remove the plastic inner wing panel, or remove the headlight assembly?
Many thanks
Andy
Threads: 7
Thanks Received: 10 in 8 posts
Thanks Given: 1
No, you push down on a white plastic lever that releases a clip just alongside the headlight. Treat it carefully as it's easily broken. Then slide the unit out frontwards.
The following 1 user says Thank You to IanR for this post:1 user says Thank You to IanR for this post
• andy325i
