Intermittent Blower
Hi all,
I have a desire 2.0HDI 53 plate (04). The blowers are intermittent. Sometimes they do not come on at all, then half way through journey they will come on.
I have no mechanical knowledge whatsoever and am willing to give it a go.
Any ideas would be most appreciated.
sound like the resistor pack do an ebay search for one then try youtube there is bound to be someone on there doing a tutorial.
  • JimmyD
Sounds like good advice. They appear to quite often get stuck on full blast (mine has done it twice over 12 years). If you search on "heater switch" you will find a couple of threads on it.
Spent 2 hours today with my head and shoulders in the passenger footwell and my feet hanging out of the drivers window fitting the resistor pack. It's not rocket science, just uncomfortable!
Worked though.  Smile
[-] The following 1 user says Thank You to Chris Baker for this post:
  • JimmyD
(10-03-2017, 08:30 PM)Chris Baker Wrote:  Sounds like good advice. They appear to quite often get stuck on full blast (mine has done it twice over 12 years). If you search on "heater switch" you will find a couple of threads on it.
Thanks all will look into it
You're doing it wrong then!
It took me 5 mins to refit mine today Smile
Remove carpet trim.
Kneel outside car, twist like a cat and look up under the dash. Remove the 3x8mm bolts that hold the heater blower in. Wiggle blower unit out, disconnect cables and rubber pipe.
Take motor unit into house, undo two screws on the base and pull the fan and motor out. Undo the two 8mm bolts that hold the resistor pack in.
I soldered new transistors in mine.
Reverse the above to put it all back together.
[-] The following 1 user says Thank You to Growler73 for this post:
  • Jeff
If you're anywhere near Reading, I have a spare working resistor pack which I can fit for a nominal sum Smile I.e. the cost of the thing itself and enough for a large Latte with 2 extra shots from Costa..
  • JimmyD
Remove carpet trim.
Fair point, I may have been stretching it at 2 hours. Unfortunately I have fitted a large dog guard behind the front seats and a dog cage behind that so the seats do not slide back very much (the usual driver is not the tallest of ladies). I could not fit my shoulders into the footwell from outside. I did consider taking out the seat, anything is better than taking all of the rest out. TBH, I needed the exercise!
  • JimmyD
Thanks for the offer but i am near Cardiff. Would be a long journey. However i would be interested in purchasing it from you so i know it the correct part........ Would you be willing to post?
Yesterday 02:32 PM
Berlingo 2026
Last Post: xtimex
Yesterday 05:06 AM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
