Do the later( 2014 ) 1.6 hdi 90 bhp engines have dpf filters
Hi, does anybody know if  a 2014 berlingo 1.6 hdi 90bhp engine has a dpf filter ???
Ian
2012 XTR Berlingo 1.6 hdi e semi auto wicked red
2016 Nissan Qashqai 1.5 Tekna manual Ink Blue
yes they do
63 plate Berlingo working hard.....
(10-03-2017, 07:27 PM)ATL_driver Wrote:  yes they do
Thanks for your reply ATL  does it also have to have Eloys fluid reason I am asking i am in the process of buying a 2014 multispace plus 1.6hdi 90 bhp  or do I keep my xtr
Ian
Yep 2012 up  Sad Eloys with the DPF / Fap until the adblu
The very latest cars no longer use Elloys fluid, but are adblue, not sure exactly when they changed, certainly most 2016 cars will be Adblue.
Thanks for your replys guys I just want to know what I'm letting myself in for by updating vehicle
Ian
I had the Elloys fluid bag split & leak on my 2009 XTR 110. It split after about 7yrs/70k miles. I don't know how much fluid was left but usually reckon about 80k miles on a bag. It lets a bit into fuel tank at every fillup so fluid should last longer if you fill fairly empty fuel tank rather than keep topping up. My Cit franchise garage charged £150 to supply/fit replacement.
My new 'lingo uses AdBlue. Seems a better idea. there is a 17litre tank & it should go between services without filling I'm told. Low AdBlue warning light comes on with 1500miles to go so plenty of time to refill. Looks easy enough there is small blue filler cap beside diesel cap. AdBlue is cheap enough so provided it don't go wrong then a better system than Elloys bag.
  • ATL_driver
Thanks for info guys, had a c5 that uses eolys it was an easy job refilling tank.
I was going to buy a 14 plate multi space plus with 34k on clock for a good price 6k. But when I actually looked at it beside my xtr I couldn't go through with it. It looked like a black van very basic so if I do change it will have to be the xtr model.
Ian
Yesterday 05:06 PM
Yesterday 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
