2.0Ltr HDi, is the fuelling shut off when on the overrun?
No problem here, just curious.
I know on some other modern cars, when going downhill, in gear, but with no throttle applied, ie on the "overrun", the fuelling is shut off completely to improve the MPG.
Does anyone know if an 05 plate 2.0Ltr HDi, does this?
Regards to all,
John - (2005 2.0HDi with Modutop roof, mini camper).
Yes it does.
Ta for that ^^^
I should stop trying to save fuel by coasting down the hills then Big Grin
Just stick it in 5th gear and take my foot off the gas Cool
Regards to all,
(12-03-2017, 07:28 AM)ghost123uk Wrote:  Ta for that ^^^
Coasting is so yesterday & uses fuel. Big Grin
No problem here, I just like to know stuff.
Yesterday I did some tests on this on some of our local country B roads.
OK, so your going  down a hill at about 30, in 4th, you have your foot off the throttle, all well and good. However, when the decent down the hill ends and there is a flat stretch, the car will keep going along, with no foot on the throttle, at it's tick-over RPM.
Question, how does it "know" when it's going downhill (or on a de-accelerating overrun) so it can shut the fuel off? (compared to trundling along on the flat, no foot on the throttle, at tick-over rpm)
Regards to all,
I wouldn't think it does cut the fuel off completely, there will always be the tickover level if your foot is off the throttle, whether you are going downhill or just slowing down.
Well that's what I was thinking, but Ron is very rarely wrong in such matters.
What do ya reckon Ron?
Regards to all,
Coasting is going to cost exactly the same as leaving it in gear even if it doesn't cut the fuel and you are losing the benefit of engine braking so you are not in full control of the vehicle. I know the BSI is doing something to the throttle as when I am in traffic inching along when the engine is ticking over in first or second gear and gets close to stalling it actually speeds up the tickover to prevent it. The car is already doing 50ish mpg driving normally, what is the point of coasting ?
  • ron
(14-03-2017, 08:30 AM)ghost123uk Wrote:  Well that's what I was thinking, but Ron is very rarely wrong in such matters.
I stick by my opinion.With throttle off & on overrun the system shuts off the fuel & when throttle applied or overrun ceases ,fuel is fed again.You don't have to believe li'l ol me.The info is out there.This has been happening since the 80's on injected petrol cars as well.I retired,10 years ago, after 40+ years in the trade & did pick up little snippets on the way. Big Grin
(14-03-2017, 11:03 AM)ffrenchie Wrote:  Coasting is going to cost exactly the same as leaving it in gear even if it doesn't cut the fuel and you are losing the benefit of engine braking so you are not in full control of the vehicle. I know the BSI is doing something to the throttle as when I am in traffic inching along when the engine is ticking over in first or second gear and gets close to stalling it actually speeds up the tickover to prevent it. The car is already doing 50ish mpg driving normally, what is the point of coasting ?
That's why you can move from stationary with a diesel using no throttle.As you say,it's a handy thing in traffic.
Oil sump design.
Today 09:38 PM
FUI: K9 tweeter
Today 09:13 PM
Which Lexia please
Last Post: Johnnyqg
Today 07:32 PM
Engine fault triangle when idle - solved
Last Post: MCRH
Today 04:23 PM
OBD Red discussion
Today 12:18 PM
» Replies: 47
Aftermarket horn help please
Last Post: Tuctuc
Today 11:37 AM
Rear sliding door jammed
Last Post: kratakule
Yesterday 07:50 PM
What is this?
Last Post: shawstvs1
Yesterday 06:38 PM
» Replies: 15
Timing chain/belt noise/issue
Last Post: Noiz_TnT
Yesterday 02:27 PM
And the lord said let there be....
Yesterday 05:56 AM
