Threads: 5
Thanks Received: 1 in 1 posts
Hi
When I turn the ignition I get a clicking sound but the starter motor does not turn
A few days ago the battery warning light came on and it beeped, it then went off and all was fine , last night it came in again and stayed on , i stoooed 10 mins later then went to start and nothing..
Headlights are bright and it has been starting just fine, does not seem like battery was flat
I managed to bump start the van on my own (much fun) and have got it home
To add I can smell an electrical smell under the bonnet , I also bout the starter motor with a piece of wood when it would not start in case it was the solenoid sticking ..did not work
Battery is only a few months old
So could be starter...or alternator ..or could it be starter relay?
Don't have an volt meter to test ?
Supposed to be using van for work toinight so pretty desperate
Cheers
Threads: 9
Thanks Given: 316
15
You need to get access to a voltmeter for starters but the burning smell does not seem good. You do have some conflicting fault signs but i do suspect an intermittent charging fault or relay/fuse box fault.
Threads: 5
Yes it seems odd the battery light came on but I seem to have good charge
I shall try and find a volt meter today
Where is the starter relay in a 2004 2.0 hdi 8v non turbo
Cheers
Threads: 9
Thanks Given: 316
15
Hi Nsr im not sure but i would think fuse box inside the cab - think o/s under steering colum. Try and start and listen, feel around for a click.
You may be able to find a owners manual on this forum somewhere that give you more of a guide?
Threads: 9
Thanks Given: 316
15
Do you have a BSI on yours? if so try a BSI reset - cant help but try - also check for water ingress = kiss of death for BSI's and it may explain the odd electrical problem - hope its not that mate.
Threads: 5
Hi I think I do have bsi....I shall do a reset of that to see if it helps
Pretty sure starter relay would be under the bonnet and heavy duty ..but will look where you suggested
Cheers
Threads: 5
Just tried again
It's now saying eco mod on the display , I can here a relay clicking under the steering wheel but not solenoid clicking ..headlights not dim
Threads: 5
12-03-2017, 12:12 PM
(This post was last modified: 12-03-2017, 01:35 PM by Nsr500rossi.)
Yok have reset bsi ..still no joy
Also after I bumped started it last night, the battery light was not on when I drive it home !!
So I am getting a clicking from the relay inside , but noting in the solenoid... I have a freind coming to help later.. will keep you posted
Threads: 32
Thanks Given: 13
Sounds like the starter to me.
Mine has gone twice and clicking was exact symptom but it would bump start.
