Fuel pump/relay
Hi All,
About 3 years ago I had a problem with my 2002 1.4 Berlingo Mulitspace. It would cut out dead when driving, coast to a stop and then re-start. This changed to stopping and  not starting at all. Pulling off the fuel connector to the fuel rail showed no fuel so Mr AA pulled the car to a local garage. The car is disabled converted so has a different (smaller, metal) tank.  Tank taken out and pump was in a poor way so new one fitted along with, they said, a fuel pump relay. All then fine for 3 years.
Moved from UK to Ireland last year so can't go back to speak to the merry man that did the work but the car has just had a couple of brief cut-outs (a few seconds) and I wonder if it is the beginning of a repeat of the above. I checked fuel supply to rail and it initially, as expected, squirts for a few seconds to prime the system and squirts continuously if the engine is then cranked.
So, I then tried to find the pump relay and from what I could find out it should be at the engine bay fuse box, which it isn't. Lifted the fuse assembly out of its housing and there's nothing underneath it either.
Can't hear any click when I operate the key but can hear the pump operate.  Thought I'd get a spare relay and pump as I live out in the wilds, and can find a relay (nonABS), but where does it go???
Also the fuses in the box are not numbered so not sure which fuse is for pump, which would be useful to know.
Cheers!
Hi the fuse identification is in the small manual (glove box sized one) or in the Haynes one if it's petrol fuse number 25.
The relay is located directly behind the battery box on a bracket off the firewall.
You need to remove the battery and box to get to it.
Cheers
[-] The following 1 user says Thank You to robfitzi for this post:
  • whitebus
Many thanks - I can have a proper look for the relay and fuse! My Haynes manual seems pretty poor on electrics and I can't seem to find any wiring diagram in it that includes or even mentions the fuel pump. Is there a better wiring diagram for a 2002 model available anywhere?
Thought a replacement 'spare' pump would be straightforward but found there's more than one and I have a non-standard tank. Presumably some of the pumps are shallower as the lists include 'side door' types.
Maybe I'll have to wait until I have the pleasure of taking the tank out before ordering, but at least a spare relay will eliminate that as a possible cause .
Regards
Joe
Have you tried the manufacturer of the conversion as they made the tank they will know what pump is fitted. Ive used Gowerings of Newbury who do thousands of conversions and they are most helpful.
[-] The following 2 users say Thank You to Tomcat3 for this post:
  • oilyrag, whitebus
Good idea - Brotherwood conversion, so I'll get in touch with them! Found the fuse OK but have yet to pull battery out to find relay - the ECU box sits behind the battery and I can't see anything on the bulkhead so I'm guessing/hoping that the relay is attached to the inner wing....somewhere!
Thanks for the replies folks!
Just a follow up - relay located - bit of an afterthought of a hiding place by Citroen, but fitted a new relay and (touch wood) it hasn't missed a beat since, so have held off doing anything about pump replacement. Thanks for the advice!
(15-04-2017, 07:59 PM)oilyrag Wrote:  Just a follow up - relay located - bit of an afterthought of a hiding place by Citroen, but fitted a new relay and (touch wood) it hasn't missed a beat since, so have held off doing anything about pump replacement. Thanks for the advice!
If this is the fuel pump relay, please could you tell me where you found it?  Ive been having difficulty finding it myself.
thanks in advance
The relay is bolted to the bulkhead, behind & below the battery box - mine is/was brownish/red, 3"x2"x1" and held in place by a single 10mm nut. Has a multiplug coming into it from below.  You really can't see it with the battery box in place and I've just checked and I can't even feel it by putting may arm down the back of it either.
Good luck!
It looks like this - https://www.auto-doc.ie/maxgear/13935329...gJLafD_BwE
  • mrwager
Hello
Today 12:11 PM
Fuel Gauge trouble
Last Post: Pricklybuzzz
Today 10:44 AM
2011 B9 DPF warning light
Yesterday 11:52 PM
Any advice regarding boot carpets being wet!?
Yesterday 05:50 PM
» Replies: 21
Yesterday 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
17-01-2025 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
17-01-2025 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
