[Steering & Suspension] Battery light comes on
Hi guys
The battery light on my Berlingo comes on when I turn the steering wheel all the way to the maximum (not something I like to do) but I don't understand why it is happening. Any idea? The light on the dash is on triggered when I push the steering wheel to the end. When the steering week makes contact at the end then it's when the battery light comes on
the same belt drives the alternator and power steering pump sounds like your belt could be slipping (too loose) or the alternator is on its way out and the belt is slipping.
  • Pariswent
What happening is when your on full lock your making the pump work hard up against the stop slowing the engine down enough to for the light to come on but check the belt anyway .
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
