rear wiper electrics
Had a Berlingo - loved it, then had a Xantia - hated it; now back to a Berlingo. When I bought it the rear wiper is stuck half way. Disconnected and checked voltages on the 3-wire connector and seem to have yellow/green earth, yellow(522) with 10 volts, Grey(520) with no voltage. These readings are the same whether the wiper is switched on or not. So, do I remove the wiper motor and replace it or should I be looking at a cable fault? Fuses seem to be ok as far as I can guess which is which. Any advice would be gratefully received (except, maybe, sell it and buy a Xantia)
Married to BandanaLady.co.uk
Connect 12v from external battery directly to wiper motor to rule out
motor faulty. On my blingo rear wiper motor is connected over relay.
Best regards,
brajomobil
Yesterday 04:12 PM
Yesterday 12:46 PM
Yesterday 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
