Horn problems
Hi Guys
I've got a 2012 citreon berlingo enterprise and my horn has stopped working  Angry  It's been playing me up for the last year really just works when ever it wants to.. there are no light showing a airbag thault on the dashboard and every thing else works perfect, yesterday morning it was working perfect by the time I drove home it stopped working, like I said it's beeb doing this for the last year just works when ever it wants too.
So my question is has enybidy else had this problem before and what they did to solve it ??
Many thanks
Ian
Hello Gashead32 and welcome to the forum.
[-] The following 1 user says Thank You to 3rensho for this post:
  • Gashead32
Hi Ian welcome to the forum, there was a problem on the old M59 model but not heard of a common fault with the newer model. You need to do the basics first check fuse then power down to the horn and then the horn its self
  • Gashead32
(17-03-2017, 07:33 AM)Tomcat3 Wrote:  Hi Ian welcome to the forum, there was a problem on the old M59 model but not heard of a common fault with the newer model. You need to do the basics first check fuse then power down to the horn and then the horn its self
Hi Tomcat3
It's the newer model 2012  1.6 hdi 3 seater Van,
I've checked every fuse in side the van (passenger side fuse box) and they are all fine, I've also checked in my citroen manual and there's a diagram of the fuses boxes, but once I opened the bonnet to check the engine fuse box and there ain't a fuse in the  place where it says in the manual so I took out every fuse and there all OK too..
(17-03-2017, 07:29 AM)3rensho Wrote:  Hello Gashead32 and welcome to the forum.
It's the same has this 1 guys
Attached Files Thumbnail(s)
I had that issue on M59 and got it sorted .... see my posting on the link below .. second post down
https://www.berlingoforum.com/Thread-MOT...light=horn
edit : Also read other postings as there are other suggestions and also a good bit of info from Brajomobil at the very end
Don't know if it's any help but I've just had that problem with my 2009 Berlingo XTR and after an hour or so of fumbling about by the dealer (still under warranty) it was a loose/corroded connection and it works now after just pulling it out & pushing it back in again. I didn't see exactly where it was but he was lying on his back with his arm up the passenger side of the front of the bonnet!
2009 Berlingo 1.6HDi (90bhp) XTR
[-] The following 2 users say Thank You to Figmeg for this post:
  • Gashead32, geoff
Hello figmeg welcome to the forum you will find the horn under the N/S plastic arch cover at the front has said check the connection's some do corroded clean them put some copper grease or silicone grease on the connection's push back on sorted .
[-] The following 2 users say Thank You to Jed Clampit for this post:
  • Figmeg, Gashead32
(17-03-2017, 10:03 PM)Jed Clampit Wrote:  Hello figmeg welcome to the forum you will find the horn under the N/S plastic arch cover at the front has said check the connection's some do corroded clean them put some copper grease or silicone grease on the connection's push back on sorted .
Thanks Jed, I don't think he greased it, it works for now so I'll just have to hope it lasts as it looked a bit of a pain to get to!
[-] The following 1 user says Thank You to Figmeg for this post:
  • Gashead32
Users browsing this thread: 2 Guest(s)
M59 roof bars/rack - flap on roof mounting point...
Last Post: charliesimpson
Today 08:10 AM
3 years 7 months
Last Post: Gadgetman
Today 07:32 AM
Diagbox user near Rochdale
Last Post: Zion
Today 06:17 AM
» Replies: 37
Newb
Last Post: Billca
Today 05:58 AM
Another Adblue question
Last Post: Zion
Yesterday 06:32 PM
PO183 Fault
Last Post: Zion
Yesterday 06:28 PM
radio smeg , engine error
Last Post: rastosel
Yesterday 05:49 PM
Berlingo Multispace 1.8i 2000 Disabled Ramp Camp...
Last Post: columoconnor
Yesterday 01:30 PM
Low Turbo Boost (still)
Last Post: Soarer
Yesterday 01:06 PM
Which battery?
Last Post: Arfcollins
Yesterday 11:35 AM
» Replies: 19
