ADVICE WANTED on2014 xtr 1.6 air dream 6speed auto
Threads: 12
Thanks Received: 6 in 6 posts
Thanks Given: 4
17-03-2017, 04:33 PM
(This post was last modified: 18-03-2017, 03:43 PM by Iank.)
Hi guys, I'm in the process of buying a 2014 xtr 1.6 airdream 6speed auto with 35000 miles on clock
Any advice or pointers on what to look for would be a great help.
2012 XTR Berlingo 1.6 hdi e semi auto wicked red
2016 Nissan Qashqai 1.5 Tekna manual Ink Blue
Threads: 23
Thanks Given: 50
29
Remember it's got a dry clutch so if your sitting in traffic don't keep it in gear has it will be an early end to your clutch or thrust bearing .
Threads: 12
Thanks Given: 16
37
Clutch is quite expensive, I am fitting one on a taxi next week, it has managed about 100k from memory, so quite impressive really.
Berlingo's generally good, just check for rattles when driving, as the repairs can rack up on the front suspension.
Threads: 16
Thanks Received: 54 in 17 posts
Thanks Given: 4
8
(18-03-2017, 07:11 AM)Lighty Wrote: Clutch is quite expensive, I am fitting one on a taxi next week, it has managed about 100k from memory, so quite impressive really.
When you say quite expensive what price are we talking about?
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
(18-03-2017, 10:53 AM)iscom Wrote: (18-03-2017, 07:11 AM)Lighty Wrote: Clutch is quite expensive, I am fitting one on a taxi next week, it has managed about 100k from memory, so quite impressive really.
The clutch is accompanyed by a dual mass flywheel, so when you change one, you change the other...
Threads: 12
Thanks Given: 16
37
Not 100% on the price yet, but I guess @£8/900 , will let you know when I work it out .
Threads: 12
Thanks Given: 4
You must work for Citroen
Threads: 12
Thanks Given: 4
Just found out car is a write off (best £20 I have spent) good old HPI worth every penny.
Everytime I buy a car private I always get a car HPI checked to make sure I don't buy a duff one or it's still on tick as once you paid for the vehicle the problems are now yours
Ian
Threads: 12
Thanks Given: 16
37
(19-03-2017, 09:52 AM)Iank Wrote: You must work for Citroen
Have you ever done one ?
8 hrs labour approx at forum members rate of £40 per hour , normally I charge £50 ph.
I guess a quality clutch & flywheel + electronic thrust bearing will be @£350, couple of litres of gear oil, etc etc brings the cost to about £700 and then vat.
So explain how this can be done for significantly less please ?
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• polar
Threads: 9
Thanks Given: 316
15
(19-03-2017, 06:11 PM)Lighty Wrote: (19-03-2017, 09:52 AM)Iank Wrote: You must work for Citroen
Usual thing Lighty people want everything done for nothing when they have no idea how much graft is involved!
The following 2 users say Thank You to polar for this post:2 users say Thank You to polar for this post
• Lighty, ron
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
