Threads: 13
Thanks Given: 12
UTouring Europe in the stealth camper is proving fun.
Last night, nearby Stuttgart, I heard a strange noise and assumed that I had run over something. Car continued as normal, reaching our destination in Switzerland a couple of hours later.
This morning it is sitting very low at the back.
I'll take dog for a walk before investigating further.
Meanwhile , any ideas, things to consider ?
Threads: 13
Thanks Given: 12
Looks like one of the rear shocks is no longer shocking, so I'll be trawling the motor factors in the morning.....
Threads: 4
Thanks Received: 20 in 19 posts
Thanks Given: 5
Shock wont be the cause of it sitting low, methinks you have broken a spring or torsion bar (depending on the model)
Threads: 13
Thanks Given: 12
After a proper look it is now clear that the torsion bar is broken.
After a proper look at this excellent forum it is clear that this isn't a roadside repair on a Swiss residential area.
Having driven a couple of hundred miles, without noticing anything untoward, on perfectly smooth roads mind, im wondering how far I can nurse it, for treatment by a Citroenologist...
Threads: 42
Thanks Received: 408 in 365 posts
Thanks Given: 137
31
Rather than try and change the broken torsion bar ( which it looks like ) you be better changing the whole sub frame assy. If you can get it back home safely you can get a reconditioned one for about £300 ish. Easier than changing one torsion bar at the side of the road only for the other one to go later.
Will it be worth it ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 67
Thanks Given: 238
50
19-03-2017, 05:38 PM
(This post was last modified: 19-03-2017, 05:40 PM by geoff.)
How much more time are you planning to stay abroad ?
Do you have Euro Recovery ( AA RAC or some such ).
I'd imagine a Swiss repair would be a lot more expensive than a UK repair ....
.....is a bodge applicable to you ( yes I know I'm gonna get shot / called all sorts / abused for saying it ) .... depending on your access to facilities at the hosts you could jack the rear up, remove each damper and fit solid suspension by using a piece of scaffolding pipe cut to damper length and a hole drilled to take the damper mounting fixings. Use the non saggy side as a length guide.
Motorcycles had solid rear " suspension " for many years without issue.
Driving home carefully would be advisable as would avoidance of an accident as an insurance inspection would prove problematic ....
Serieal Berlingo owner
• ian432
Thanks Given: 188
23
Brings back memories of strapping axles on artics because suspension failed and miles from base.
Are we there yet?????
