  • 1 Vote(s) - 5 Average
Rear window heater
Hi Guys (and gals),
Any idea on fixing a rear window heater without replacing the whole glass?
It seems to work in some areas ( a couple of lines) but not others.
Any help would be appreciated.
You can get some electric conductive paint in silver, just find the brakes in the heating element and bridge them with the paint. A modeling brush is ideal for applying the paint.
something like this would be ideal:
http://www.ebay.co.uk/itm/Conductive-Ele...xyCTtTdLcF
Thank you for the reply.
I cant seem to see any breaks in the lines. There are parts where it gets fainter  i have looked at the descriptions of the paint and it says not to put over existing "print".
If I was to go over the lines it would probably work
You can find really easy where line is not conducting.
Take 12v bulb . One end of wire connect to +12 and the other end pull slowly
across heater line. When bulb stops lighting you found break.
There is a thread about fixing rear heater with conductive paint.
Just use "search" forum function.
Best regards,
brajomobil
Thanks all will be looking to do this next weekend
Last Post: stu76
Today 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
