2010 1.6hdi - speedo fault
Just picked up a Berlingo 1.6 HDI, stupidly on test drive I didn't notice the speedo wasn't working and parted with my cash so now I'm stuck with a faulty speedo.
Anyway I'm hoping you guys can help me, the rest of the binnacle is working fine other than the speedo and the milagage/ trip computer.
I suspect it being a sensor but no idea where it's located and how to diagnose that's definitely the problem.
Any info is much appreciated.
Probably faulty sensor.
You can use "search" forum function and you will find answer in 15 min.
Best regards,
brajomobil
So a little update. I found the location of the speedo drive sensor (at the back of the gearbox just in front of the gear linkage rods if anyone is interested)
Replaced the old part with a new one and the speedo still isn't working.
I've checked the drive gear inside the gearbox and that moves when the wheels rotate but for some reason I'm not getting a reading on the speedo.
Had the van to the local auto electrician who had it in a Bosch computer but couldn't find any faults. I tried attaching the speedo drive to a drill and spinning it to see if the speedo registered anything but no joy.
Starting to think there's a problem in the wiring loom.
Getting really frustrated now.
Your best bet would be connecting it up to the citroen/Peugeot Lexia software and look for faults. There may be a member near you with the software who could help for beer tokens or have a look on French car forum and check out their map for Lexia user near you.
Uh, then you will need to check wires from sensor to BSI.
If you need schematic , shout.
Best regards,
brajomobil
[-] The following 1 user says Thank You to brajomobil for this post:
  • Bradjohnson
Schematic would be brilliant if you have it.
Kind regards.
Tacho, speed sensor is number 1620 on pdf page1
You have 3 wires to check
Wire 1
pin1 CM01D goes to connector 16v NR pin 2
16v NR connector is on PSF1 fuise box PDF page3  "A" picture
Wire 2
pin2 M162 goes to GROUND
Easy to check with ommmethar
Wire 3
pin3 7638  goes to connector 48V MR pin B3
48V MR connecor is on engine ECU PDF page3 "F" picture
.pdf   berlingo_speed_sensor_page1.pdf (Size: 444.21 KB / Downloads: 45)
.pdf   berlingo_speed_sensor_page2.pdf (Size: 578.63 KB / Downloads: 33)
.pdf   berlingo_speed_sensor_page3.pdf (Size: 473.01 KB / Downloads: 39)
Best regards,
brajomobil
Spot the Berlingo(s)
Today 05:54 PM
knocking from rear
Today 04:59 PM
Last Post: Andhall
Today 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Today 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Today 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
Yesterday 08:28 PM
wipers
Yesterday 06:17 PM
Last Post: xavier988
Yesterday 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
