Berlingo door panel pins and inserts
Hi
I had to remove the door panel to get access to the door stop which I wanted to change. I did the job but along the way I broke a few pins while removing the panel. Found pin replacements on eBay.
So far so good, however I noticed the inserts retaining the torx screws (torx screws are concealed in the door handle) are also broken so I can't screw into them.
Anyone knows where to buy them or how these inserts are called in order to make a search online? The inserts are white and rounded and the two torx screws should screw into them.
Thank you
Picture showing the torx screw[Image: f16e861f22358c1d01d28e5e5d11e977.jpg]
I think (and not just for your specific reply alone) if anyone knows of an online parts catalogue for the Berlingo could they please let us know....This would solve a lot of problems like this as I too look for parts and not knowing the actual names of these makes them more difficult to locate...There are fantastic ones out there for my BMW and I cant see why Citroen don't have one .......
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
http://www.eurocarcare.net/
Captive nuts, they come in a lot of different types and sizes
  • Pariswent
(20-03-2017, 08:03 AM)ffrenchie Wrote:  Captive nuts, they come in a lot of different types and sizes
Thank you! I would just now need to find out exactly which captive but will fit in the door. It's tricky. Any suggestions? I bet if I just buy a standard captive but it will be either too big or too small fit
If you have an old fashioned car parts shop the guys usually have trade boxes of fittings. Take yours along and compare and I'm sure you will find what you want.
  • Pariswent
Side Light Bulb Holder
Last Post: Starkebab
Today 10:52 AM
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
