Stud pattern and offset
Hi,
Looking for a bit of advice here please.
Can anyone tell me the stud pattern (I think its 4x108) and more importantly the offset for a 2015 Citroen Berlingo van (Enterprise Hdi) I'm looking to go with perhaps  17" Team Dynamics Pro Race 1.2 (but not yet set in stone)....
I like the look of this set up......
In Gunmetal or similar.
Any thoughts or alternatives bareing in mind the van is Arctic Steel in colour
any help/advice always appreciated
Regards
C
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
4x108 off set 27  Smile
  • BigC
Cheers buddy
If you are buying aftermarket wheels you need to check the centre bore size as well. Ford use the same pattern but smaller centre. Wheel size Paint your wheels whatever colour you think looks best with your van.
Cheers mate...
Can anyone give me the proper bore Diameter for the van please
Regards
C
(23-03-2017, 12:52 PM)BigC Wrote:  Cheers mate...
Regards
C
It's in the link where it says wheel size Big Grin
I'll put it here for you though 65.1mm
  • BigC
DOH.....Thanks again buddy...appreciated
Regards
C
Will CITROEN C4 17" ALLOY RESOLFEN WHEELS fit my van...Need a yes or no please (2nd option)
(2015 1.6 hdi Enterprise)
Regards
C
(23-03-2017, 06:09 PM)BigC Wrote:  Will CITROEN C4 17" ALLOY RESOLFEN WHEELS fit my van...Need a yes or no please (2nd option)
Regards
C
Yes
Sent from my SM-T585 using Tapatalk
2006 Berlingo 2.0hdi desire daily hack
1998 Xantia Activa turbo for fun.
[-] The following 1 user says Thank You to david.mckay.3760 for this post:
  • BigC
Brilliant David, many thanks
Regards
C
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
