[Engine] ENGINE 1.6HDI rebuild got screwed with garage
Shocked
update from https://www.berlingoforum.com/Thread-Eng...-fuel-line
so the engine is up and running instead of having an engine problem i had a theft problem i bought a 2nd hand engine got 2 brand new air condition system with it, had it left at 1 garage which bill me  around (2500 pound sterling)
Component stolen:
- Battery still under warranty and battery support
- Common rail sensor
- mud guard right driver side
- wipes water tank
- 2 air condition system
- New timing belt
- Old engine block
- Air condition pipe system removed
- Engine oil pan removed
- Turbo gate valve
- exhaust cover
- Turbo cover
- Rubber OEM pipes replace by water pipe
- Oil seals
- Broken rubber support back engine
-3 oil ring set
- Engine sensors
- Water pump
- Pulleys
- Tensions
- Screws missing from original fixing parts
- Air condition belt
from 30/09/16 to 12/03/17 it was on repair :3 , now i got it and sometime lost all interest in that vehicle,
i wish to know if belingo 1.6HDI are so bad what they claim?
also i wanted to know if the interior dashboard can be upgraded to something new such as this or some upgraded models: [Image: citroen-berlingo-airbag-dashboard-gordel...7857_1.jpg]
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
