Knocking from the frond end
Hello,
I have tried to fix a knocking sound in the front end by changing the anti roll bar drop links, control arm bushings, and the lower ball joints. Still no luck, I now wonder if changing the top strut mountings can help?
Would this kit be enough?
http://www.ebay.com/itm/SWAG-62-92-2131-...SwoBtW6ulQ
Also check your springs one might of snaped
Have the same problem on the left hand side on my 2011 VTR and my previous M59. Citroen agent unable to find fault. On both cars drop links changed, the first was fitted by a garage at £75.00 and the knock never came back, but my VTR only worked for the first 5k miles, but cost only £20.00, obviously a cheap part? Only knocks over very rough surfaces, which means most UK roads. Very annoying!
Just had my front spring replaced after it snapped. However, it had been snapped higher up for ages and I was unaware and thought the odd rattle would be the drop links.
The earlier snap had rusted up. So could be the spring but not easy to see the break.
I will have a closer look on the springs. Does anyone know if the kit i linked to is the correct one?
Some top mount's fit better than other's some stop the knocking for a short time then it comes back other don't .
The top mounts only knock if the centre bush has noticeably deteriorated , I am seeming to find it's generally the damper that is faulty, but you cannot see any fault with it on inspection.
Last Post: Desdinova
Today 05:46 PM
Yesterday 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
