[Tires & Wheels] locking nuts
I bought my 12 Reg two years ago, with 11000 on the clock, and I like to replace the tyres but the wheels are fitted with locking nuts,  the key to the nuts is missing, I have never seen them, it news to me that there is locking nuts fitted, can anyone help please?   Kind Regards
Would this help perhaps......
 LASER LOCKING WHEEL NUT REMOVER 2 PACK
Regards
C
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
[-] The following 1 user says Thank You to BigC for this post:
  • Eijac
Hi Eijac welcome to the forum. You could try the original supplying dealer or citroen direct and ask if they have details of the missing socket. Have you searched the car for the socket try all cubby holes is it with the jack and brace. Last resort is you can get removal sockets to get the bolt out but they tend to trash the bolt so you will need a new set of locking bolts. Most tyre fitters have a set of removal sockets.
  • Eijac
Ditto as Tomcat3 (primary)
I had locking wheel nuts on my Pug. The dealer said that they always give bother, and so I removed them, as it makes it easier for the tyre fitter and mechanics. The locking nuts can break down over time. Now seriously: who is going to steal a set of common French alloys?
If a thief wants them and they are for nothing with good tyres on believe me they will have them, even if they only fetch a few quid.
(25-03-2017, 05:35 PM)Eijac Wrote:  I bought my 12 Reg two years ago, with 11000 on the clock, and I like to replace the tyres but the wheels are fitted with locking nuts,  the key to the nuts is missing, I have never seen them, it news to me that there is locking nuts fitted, can anyone help please?   Kind Regards
A tyre shop will remove them for you - they have this problem all the time, you wont see many tyre fitters with locking wheel nuts fitted to their cars  Wink
We remove them all the time, although you won't get them off with that laser tool shown above, I weld onto the bolt with the mig welder & use a scroll tool to extract them. The heat from the welder also helps loosen the bolt when they are very tight.
We usually do a set per week, & the cost is £10 per wheel + vat and £3 each for a new normal bolt.
This just give some you an idea of the cost.
  • daviddb
Today 12:33 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
