[Engine] Head gasket kit quality
Hi, I'm planning to rid off engine oil consumption problem and have seen a gasket kit set off ebay but the price is cheap and there is no indication of which brand the items are. Kindly check out the link herein for me and advice if they are any good. http://m.ebay.com/itm/220488122456?_mwBa...noapp=true
Best advice is to contact them and ask ....
SALES - 01924 451277 / 01924 51 00 00 - OPEN: MON-FRI -9.15AM - 5.00PM SATURDAY 9.30AM - 3.00PM SUNDAY CLOSED
They are a " Motor Factors " so should be ok .....
When you hear from them post up the makers name.
edit : just seen the Kenya location so perhaps the internet would be easier / cheaper than phoning.
  • Civvic
(27-03-2017, 03:23 PM)geoff Wrote:  Best advice is to contact them and ask ....
Yes, I've emailed them requesting whether they are of oem quality and the brand name and the only response I got is that they are quality.
if anyone here has used them, I'd appreciate input.
If you want peace of mind then fit " Elring " or " Payen " or " FAI "
[-] The following 2 users say Thank You to geoff for this post:
  • Civvic, ron
(27-03-2017, 04:05 PM)geoff Wrote:  If you want peace of mind then fit " Elring " or " Payen " or " FAI "
Thanks Geoff, I've replied again requesting for the manufacturer/ brand of the kit and if I get no feedback I'll give it a miss. I'm off to misterauto.
Depending on where you buy / perhaps buy seperate, Febi make good head bolts.
(27-03-2017, 02:34 PM)Civvic Wrote:  Hi, I'm planning to rid off engine oil consumption problem and have seen a gasket kit set off ebay but the price is cheap and there is no indication of which brand the items are. Kindly check out the link herein for me and advice if they are any good. http://m.ebay.com/itm/220488122456?_mwBa...noapp=true
Given your location, I would avoid this item. There's a chance it will be ok but then again maybe not. As you're not in the UK I doubt you'll have much in the way of consumer rights and returns will be expensive. Best to get a known brand item in this case IMHO.
  • Civvic
Thanks. Will take your advice into account when I make final decision. Locally the items are not sold as a kit. Other than the head gasket, the other gaskets are normally not in stock. A quality HG costs around 40GBP, and quality bolts around 60GBP hence the
attractiveness of a deal of 54GBP for everything
Non start , turns over
Today 12:20 PM
Looking for breakers with Petrol M59
Today 10:29 AM
MyCitroen App
Last Post: Blakey
Today 08:01 AM
Whats the S for? 19oC/19oC S
Last Post: Hughzie
Yesterday 04:33 PM
What does a service consist of ?
Last Post: StarFish
Yesterday 01:46 PM
Ad blue use age
Last Post: curlywurly1971
Yesterday 08:46 AM
Air con re gas
25-05-2024 06:24 PM
Free undertray for 2011 multispace
Last Post: needsmust
25-05-2024 10:44 AM
25-05-2024 09:49 AM
99bhp & 128bhp same engine?
24-05-2024 09:42 PM
