28-03-2017, 08:43 PM
(This post was last modified: 28-03-2017, 08:44 PM by Multispacer.)
My 2008 Berlingo Multispace 1.6Hdi XTR seems to have developed the knock that many others have from the front end. I've replaced the drop links [as they were quite worn] but it doesn't seem to have made any difference. Had the vehicle up on axle stands and checked for broken springs, track rod end wear and lower ball-joint but all seem OK [and in fact it has only recently gone through a MOT where I asked them to double check and they couldn't find anything] The only thing I have noticed, both when it was up on the stands and when I first turn the wheel when driving off, is that I sometimes get a knock. This appeared to be from the inner track rod end when I had it up on the stands [and the MOT person informed me inner track rod ends are not an MOT fail]
Based on that I am going to replace both inner track rod ends but here is where the fun starts, there appears to be a multitude of differing lengths of inner track rod end, do I need my VIN number to be able to purchase the correct one? Also I believe to make the job a lot easier you can buy a inner track rod end removal tool, but again there appears to be a lot of different size ones on the market. What size is needed for a Berlingo? Finally, as I will be removing the outer track rod ends to gain access to remove the inners, is it best to also replace those at the same time? [vehicle has done approx 80,000 miles]
Thanks for any help.
