  • 24 Vote(s) - 1.67 Average
Just a rant!
WHO invented that stupid bloody nut to get the spare wheel out the car with a hook on the end of a wheelbrace? what an idiotic way to get ya spare out, av gave up tonight, i have a flat luckily in my driveway, its pitch black, my lamp dont work and to top it off i cant get the nut off to save my life, the designer of said nut needs a kick up the hole, am furious and am leaving it till the weekend when i can actually spend time in daylight to see how big a hammer am gonna need!
Rant over!:brickwall:
Anyways, i hope you all had a pleasant day!Big Grin
[-] The following 1 user says Thank You to DEZZIE for this post:
  • 3rensho
Ha ha! I welded a 17mm nut to the top of mine so it fits the berlingo wheel brace Big Grin
Think yourself lucky. I have the anti-theft device too - basically a BFO bolt going through the boot floor into a threaded plate fixed to the spare. Needs a 19mm spanner/socket. Judging by the struggle the tow-bar fitter had refitting it I won't be wanting to do that in the dark and rain :-(
2004 Berlingo Multispace Forte 2.0HDi in red.
After gaining a nail and losing a tyre during the first week of ownership, I rapidly found out what a s**t idea the spare wheel carrier nut is.... First job was to remove it completely, clean up the threads on the bolt and the hook, apply anti-seize compound and refit. Not got round to "modding" to fit 17mm hex yet...
(27-10-2011, 09:28 AM)andy-womble Wrote:  After gaining a nail and losing a tyre during the first week of ownership, I rapidly found out what a s**t idea the spare wheel carrier nut is.... First job was to remove it completely, clean up the threads on the bolt and the hook, apply anti-seize compound and refit. Not got round to "modding" to fit 17mm hex yet...
I also had to do the copperslip thing, it took the heat from a blowlamp and a lot of swearing and sweating to get it off to start with, well designed Citroen........ Big Grin
Glad to have that info. Will have a look at mine this weekend and get out the can of WD-40. Is copper-slip a better anti-sieze compound? I've never heard of it but it sounds like I should look into it.
(27-10-2011, 04:54 PM)3rensho Wrote:  Is copper-slip a better anti-sieze compound? I've never heard of it but it sounds like I should look into it.
Yes, you can get it in little tubes for a few quid or a big tub for around 7 quid.
[-] The following 2 users say Thank You to steve valentine for this post:
  • 3rensho, ron
I've been using it for about 35 years now, used to use it a lot when I worked in the coal industry. The environment where some of the plant vehicle worked was quite often wet and corrosive and it always seemed to do the trick.
A little tip, if you do buy a tin, sometimes it needs a little drop of oil adding to thin it down as the oils seem to drop out of suspense in the mix. I use a small container like an old film cannister or similar and keep it topped up from the main tin...
[-] The following 2 users say Thank You to andy-womble for this post:
  • 3rensho, ron
Thanks for the info. Will look for some.
The mk3 has a nut that fits the wheelbrace. The mk2 has the slot.
Timing belt change interval
Today 03:06 PM
» Replies: 19
B9 tailgate lock
20-04-2025 01:58 PM
Tie rod end bad almost every year
19-04-2025 10:56 AM
Water Leak Boot (tried a number of suggested fix...
19-04-2025 10:49 AM
AC Compressor Clutch
Last Post: tomhick024
18-04-2025 05:36 AM
Cruise control retrofit
17-04-2025 08:15 PM
Exhaust bracket
Last Post: timpascoe
17-04-2025 12:29 PM
Last Post: Mehal888
15-04-2025 12:57 PM
» Replies: 75
Washer Pump *Brand New unopened*
Last Post: Antdad
13-04-2025 05:47 AM
2.0 hdi clutch
Last Post: Martinez
13-04-2025 01:11 AM
