Removable rear seats
Looking at possible purchase of new (April 2017) Petrol Tepee or Multi-space
Do all models have removable rear seats?
If not which ones do have?
Hello PdLG welcome to the forum good to have you with us Smile The Berlingo will have three removable seat's the Tepee the three seat's are an optional it can have 60 / 40  the cruse control you get on the Tepee but is optional on the Berlingo so you'll have to check each one for speck HTH .
PS because the Tepee / Berlingo are coming to the end of their run you may get some extra's put on them has standard so it's best to check them out . Smile
"because the Tepee / Berlingo are coming to the end of their run"
I didn't know about this, any more info?
New model with new body shell out in 2018. Search internet for pictures. I wouldn't let it put you off current car though. New car looks even bigger & current car is bigger than previous model which for me was perfect size. Good deals on current model & mine is mid range Feel but came with cruise control, foglights smoked rear windows, opening tailgate window. They threw in swan neck towbar/13pin electrics for £16k all up. This for 1.6 diesel so petrol should be £1k cheaper than that. Dunno about 1.2litre 3cylinder turbo petrol though when you can have more economical & well proven 1.6 diesel.
To answer your question both midrange 60/40 rear seats & top of range 3 rear seats can be lifted out & removed. This on Berlingo so presumably on TeePee as well.
If you are planning to remove seats often, then you will find that the three separate seats are easier to lift out than the 60/40 standard fit on the Peugeot.  the 60 section would be nearly twice the weight and is a two man lift.
Thanks to you all for your input.
I have ordered a new tepee outdoor petrol.
As a matter of interest, the salesman said that the percentage of diesel is less lately.
Patrick
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
