Threads: 23
Thanks Received: 28 in 22 posts
Thanks Given: 60
8
Hi
I am about to order genuine sets of front and rear mudflaps for my 2015 Enterprise van
Are they easy enough to fit properly by myself
or should I leave it to the Stealers
Any assistance or walkthrough procedure would be appreciated on this one please
Regards
C
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
Threads: 3
Thanks Received: 6 in 5 posts
Thanks Given: 2
BigC yes those are the ones that came with mine, plus them crappy flat push on thread clips and screws.
Sent from my iPad using Tapatalk
The following 1 user says Thank You to Corker for this post:1 user says Thank You to Corker for this post
• BigC
Threads: 23
Thanks Given: 60
8
Thanks again Corker.
Did you have to take the front/rear wheels off to get at the spot you wanted to drill
Regards
C
Threads: 3
Thanks Given: 2
Big C yes I took the wheels off for the easiest, but you might get away with jacking the body up and turning the wheel to give more room.
• BigC
Threads: 58
Thanks Received: 691 in 589 posts
Thanks Given: 174
44
If the van is a " keeper " .......... when the drilling is done put a dab of paint on the hole and the fixing that goes into the hole, this will seal the lot from corrosion from inside out. Then put the " other " stuff on ....
Serieal Berlingo owner
• BigC
Threads: 23
Thanks Given: 60
8
31-03-2017, 08:43 PM
(This post was last modified: 31-03-2017, 08:46 PM by BigC.)
Yes Geoff the van is definitely is a keeper as I've only just bought it and about to subtly do a few mods to it. (See other thread in Members Berlingo section)....
Thanks for your reply, much appreciated..
Regards
C
Threads: 58
Thanks Given: 174
44
No problem .... I have an innate hatred of rust ................................................................................
