Threads: 7
Thanks Received: 27 in 25 posts
Ok i have a 2013 B9 75 Berlingo van i wanted cruise control i have got laptop with A version of lexia on it i dont know what version Lexia or how to tell i have looked everywhere for this info in case i need to upgrade. All i know is all the instructions i have found on how to activate this (3 versions) none look like my screen but i am in there and seeing info but i cant see anywhere to activate cruise control so suspect its not there or need a upgrade or do i need to plug the cruise control switch in for it to be seen then activated ?. I have had a good look around in there at most of the settings and did find a cruse control button but no option to activate it. I do have the switch on the clutch checked that and read any and all info i have found on here and the neT but somebody that has played around and knows straight ans to this would be good
Any info greatly appreciated
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
I don't believe Lexia is of any use on aB9 Berlingo, you need Diagbox
Threads: 12
Thanks Given: 16
37
I think any version will do.
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
First check if your car has all that is needed fitted: the clutch and brake sensors are quite easy to spot on the footwell. Then, if you do have these, install the cruise control stalk in place, and then proceed with the activation. For a 2013 car you should have a more recent diagbox version, I think...
Threads: 4
Thanks Received: 20 in 19 posts
Thanks Given: 5
Have you fitted the control stalk? Don't think it will display the option until you do!
Threads: 23
Thanks Given: 46
5
If it is not fitted I would suggest you cannot activate it.
