Windscreen Washer Nozzles
Hi
I'm trying to find replacement front windscreen washer nozzles.
Looking on eBay I've found only a couple in the UK, but say they are for a Mk2 2008 onwards, so I assumed I had a mk1 until I discovered this forum, which seems to say that a mk2 is 2002-2008.
I have a 2003 model, so should be a mk2?
Would this fit:
http://m.ebay.co.uk/itm/171073205577
Thanks,
Richie
(02-04-2017, 11:54 AM)Richie1972 Wrote:  Hi
Would this fit:
Thanks,
Richie
The size and type of the headlight should assist you tell the two apart. Mark I glass headlight with slim design and bonnet tapering downwards towards the front while for mark II the lights are bulbous big crystal type with less bonnet taper. The body chassis of the old one is designated as M49 for the Mark I and M59 for the Mark II. I hope this helps.
Thanks.
So attached photo to help, but I'm thinking mk2?
Richie
Attached Files Thumbnail(s)
(02-04-2017, 02:27 PM)Richie1972 Wrote:  Thanks.
Richie
Right.
[-] The following 1 user says Thank You to Civvic for this post:
  • Richie1972
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
