HEEEEELLLPPP !!!
Needed.
Right guys, I had a problem with the Berlingos radio from day one, if you remember.
An aftermarket radio had been bodged in, which meant you needed to remove the face of the radio in order to turn off the dash lights, and he same in reverse at night, if you wanted the dash lights to work.
I have been offered the radio from a 2001 Peugeot 206 1.4 petrol, photo below.
It will come with a lump of the original wiring loom beyond the multi point plug, so hopefully my mate amartin can make some sense of the wiring, which is one of these modern systems that carries messages around and not just current. Yes, I have no clue.
Anyway, does anyone know if the radio is interchangeable??
I have done a Google search for 2001 Berlingo radios, and the photos that come up, looks the same as the Peugeot 206 unit.
Any advice greatly appreciated.
Radio in 206.
Needed.
Radio in 206.
![[Image: 8A71553C-54B4-413E-87C0-AEB1BC3C6758_zpsbyekm7as.jpg]](https://i294.photobucket.com/albums/mm90/niknakpix/2015%20Continues/8A71553C-54B4-413E-87C0-AEB1BC3C6758_zpsbyekm7as.jpg)
