Anyone remapped 1.6HDI?
Anyone remapped 1.6HDI? Can it be done through OBD or does it need to be done on the bench?
Is it worth it? Any issues with reliability? Clutch / Turbos / DPF etc?
(10-04-2017, 02:57 PM)cascas Wrote:  Anyone remapped 1.6HDI? Can it be done through OBD or does it need to be done on the bench?
Galleto v54 can do it over OBD or BDM.
If you don't have vnt turbo then you will not gain much.
If you have vnt turbo and you get map and galetto for 100$,
you will get back that 100$ in diesel savings by 3-4 months.
But, you must pay more attention to your car. More frequent oil change.
Than you will lose more money on service.
If your map is not that good you will not pass MOT. You will need to flash old
map before MOT.
It is not that easy to answer your question.
Best regards,
brajomobil
Depends what year it is....Have a look at http://www.hdi-tuning.co.uk/ecu-remappin...pport.html for all the info you need. I had mine remapped from 90 to 110 and its been great, with no issues. Pulls loads better than a 90- not too much smoke either, only when you boot it.
Hi,
I found this  update to 148 CV.
Only need change the injector and turbo from original HDI 110 CV and remap the ECU.  Big Grin
Regards
.pdf   GT1544V-turbo-110injector-upgrade-guide-1600HDI-TDCI.pdf (Size: 1.28 MB / Downloads: 18)
Vigo, The cradle of all Berlingos / Partners.  Big Grin Heart
Side Light Bulb Holder
Last Post: Starkebab
Today 10:52 AM
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
