Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
Hello all,
I've got a factory standard RD4 radio/CD player in my B9 Berlingo. The FM radio reception is very poor, only the strongest local stations are listenable, often even they cut in and out. My home and other car FM radios work just fine around here.
What sort of FM reception do you other owners get?
Has anyone any experience of the problem and cured it? Might my aerial be faulty?
Thanks,
Matt
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 52
Thanks Given: 87
5
No problems with reception on mine. I'd check antenna as a first step. Unscrew it and make sure there is no corrosion or other impediment to connection.
BTW, I deleted your second, identical post to avoid confusion.
The following 1 user says Thank You to 3rensho for this post:1 user says Thank You to 3rensho for this post
• Matt Haigh
Threads: 16
Thanks Given: 46
5
15-04-2017, 02:42 PM
(This post was last modified: 15-04-2017, 02:45 PM by Opensauce.)
Is your RDS switched on? This allows radio to find strongest signal for station. If it is on it will show 'RDS' . on the screen. If not go into radio menu & switch it on.
Threads: 4
Thanks Received: 12 in 12 posts
Thanks Given: 8
My radio reception is poor and has been from new, I put a bigger aerial on and it made no difference whatsoever.
Sent from my SM-T580 using Tapatalk
2012 Berlingo XTR 110 in Iron Grey
Money cannot buy you happiness but it far better to cry in Ferrari than on a bicycle
The following 1 user says Thank You to Bigian for this post:1 user says Thank You to Bigian for this post
• Matt Haigh
Threads: 54
Thanks Given: 147
7
I won't renew the Aerial then! But I will check aerial connection at the radio end.
I did check to ensure that RDS was on, and it was, but reading this Citroen C4 forum item on RD4 radio it might be that the RDS is actually the problem.
http://c4owners.org/plugins/faq/faq.php?0.cat.2.26
Matt
previous
Thanks Received: 3 in 2 posts
Thanks Given: 4
Do you have a USB adaptor plugged into the 12 volt cigarette socket ? If so, try removing it.
Some of these adaptors are poorly designed and radiate hash all over radio spectrum, giving exactly your symptoms.
The following 1 user says Thank You to nicko for this post:1 user says Thank You to nicko for this post
• Matt Haigh
Threads: 67
Thanks Given: 237
50
RDS isn't that the bit that allows your listening joy to be rudely interupted by traffic alerts ?
Serieal Berlingo owner
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
20-04-2017, 10:39 AM
(This post was last modified: 20-04-2017, 10:48 AM by Luis Rosa.)
I had a older RD4 radio unit in a PUG 307 that had an interesting feature, that when activated, would give this apparent behavior of poor FM reception: it was about focusing the automatic tunning of the radio stations in a "local" mode or in a "nation wide" mode. When nation wide mode was on, the radio could only tune to 2 or 3 nation wide emitter radio stations, ignoring all other weaker, local radio station signals...when off, it could tune all stations, like a normal radio would...
You have to fiddle around with the AF and REG functions, and see if the FM reception improves...
