Multispace parts onto/ into van
First questions here, be nice  Rolleyes
I have a 2017 berlingo van and wanted to do something to change it up a bit.
Going to get the bumpers colour coded but wondered if (providing the wiring is there and i can sort the correct light stalk) i can fit the front fog/ drl lights off the new multispace or is it easier to fit the whole bumper?
Also i presume the headlining from a multispace will fit the van?
TIA.
So after speaking to a main dealer he thinks the fog lights are easy enough but says you can not fit the Multispace DRL/ Fog light units as the Berlingo ECU will not take the DRL part?
Seems odd they would use a different ECU in basically the same car?
I've got colour coded bumpers and DRL's on my van. The DRL's would have to be programmed into the bsi so it shows up on the touchscreen as an option.
(29-04-2017, 07:41 PM)Tree Wrote:  I've got colour coded bumpers and DRL's on my van. The DRL's would have to be programmed into the bsi so it shows up on the touchscreen as an option.
So it's possible then, think i'll wait for the right full bumper to turn up in a salvage yard  Dodgy
Can't see why not, I ticked mine on the options list when I bought it.
[-] The following 1 user says Thank You to Tree for this post:
  • durrusvan
(29-04-2017, 07:46 PM)Tree Wrote:  Can't see why not, I ticked mine on the options list when I bought it.
Time to start searching then  Big Grin
Oil sump design.
Today 09:19 PM
FUI: K9 tweeter
Today 09:13 PM
Which Lexia please
Last Post: Johnnyqg
Today 07:32 PM
Engine fault triangle when idle - solved
Last Post: MCRH
Today 04:23 PM
OBD Red discussion
Today 12:18 PM
» Replies: 47
Aftermarket horn help please
Last Post: Tuctuc
Today 11:37 AM
Rear sliding door jammed
Last Post: kratakule
Yesterday 07:50 PM
What is this?
Last Post: shawstvs1
Yesterday 06:38 PM
» Replies: 15
Timing chain/belt noise/issue
Last Post: Noiz_TnT
Yesterday 02:27 PM
And the lord said let there be....
Yesterday 05:56 AM
