Threads: 4
Hello,
Does anyone happend to know what brake disc is fitted on my 2011 Peugeot B9 Dangel 4x4? It seems to be the same diameter and thickness as the non 4x4 version of this car. The main difference is that the 4x4 brake disc does not have an integrated wheel bearing.
I have this number, which I am told is an original Dangel part number; 3671711091, but I can't find anything on that.
The Peugeot dealer wants an insane amount of money for this standard, non-ventilated brake disc..
Threads: 4
Is threre any website you can search for breake discs based on the dimensions?
Dangel Automobiles told me to bring the part number to a Peugeot dealer, and said this disc is specific for this vehicle. Can it really be?
Threads: 4
Most catalogues is viewed in the browsers and is not available as a pdf. Am I wrong?
Threads: 0
Thanks Received: 1 in 1 posts
No one solved this problem? I need to replace my aft discs om a 2015 berlingo, but can’t find any good replacement for the 300€ original ones.
Threads: 28
Thanks Received: 372 in 326 posts
Thanks Given: 63
19
They will probably be non vented front discs from a smaller model. You will have to check the size and the offset of a few to get something to fit. €300 does sound a lot for a pair of discs when a pair of Fiesta solid front discs can be bought for under £10.
Threads: 59
Thanks Received: 40 in 30 posts
There is no aftermaket replacement for the dangel. you have to buy if from citroen. I have tried to find it in brembo. promeister, bosch, comline, sbs. but no one has it.
Threads: 8
Thanks Received: 493 in 443 posts
Thanks Given: 294
29
02-11-2021, 10:29 AM
(This post was last modified: 02-11-2021, 10:06 PM by jj9.)
Are they not the rear disks from the Peugeot 405 4WD ?
Apec part # DSK182
