19-04-2017, 08:17 PM
Hello all, thought I'd give an update on the slightly troubling Blingo 1.9 that I recently purchased! Just enjoyed a 350 mile trip to Glasgow, which the Blingo took in its stride - only breaking down once.
Some things have improved/been fixed since my last update, some things have become worse/appeared.
Things fixed:
Things fixed:
- New air filter, fuel filter, oil change, new glow plugs(3/4 OK, 1/4 over tightened and sheared) throttle and clutch pedals and cables greased, a few rattles and squeaks quenched.
- New cambelt and auxiliary belt by garage (they took a look at my knocking issue, but couldn't find anything. Seems to have improved since so perhaps tightening something up or placebo effect)
- Engine overheats in general at low speeds (stop/start).
- Something smoking in engine bay (front, near alternator) when engine warm. Acrid smell. (potentially unrelated to overheating).
- Bad smelling air vents (improves slightly after vents on for a while, worse when hot). Dusty and acrid.
- Knocking suspension/engine mount/clutch. Yet to be diagnosed. More annoying rather than disastrous.
- A little grumbly when starting cold, but much better than before.
- Just noticed an interesting and mildly terrifying fuelling issue - When nearing empty tank (1/4 to light on) hesitations in power up hill with constant throttle, better downhill. Engine completely konked out when come to stop on motorway sliproad up hill. CPR on fuel primer and full throttle needed to re-start.
- Battery light occasionally comes on and beeps, not sure why - thinking aletrnator but need to check.
