Threads: 48
Thanks Given: 4
20
Which year is your Berlingo?
(In 2000 they added the BSI)
Which gearbox do you have?
Note that the flywheel sensor sits in a cutout on the bellhousing, so if the engines uses different sensors, you may be in for a bit of a bind. (This was an issue when I swapped 1.4i engines.)
Threads: 10
Thanks Received: 2 in 1 posts
necropost i know, i have an 05 1.9 dw8
would it be a ball ache to fit a 1.6hdi or 2.0hdi?
dw8 is just dead as hector
Threads: 29
Thanks Given: 67
20
(17-09-2018, 07:21 PM)big_chris88 Wrote: necropost i know, i have an 05 1.9 dw8
It would, needing a new wiring loom and BSI would make it complicated and expensive. More sensible to buy a different model Berlingo.
Threads: 123
Thanks Given: 250
34
A common rail diesel with turbo is likely to need extra wiring & a different ECU / BSI. Lots of good price 2.0 HDi's for sale...
