Aircon not working. No clunk when button pressed.
Hi gents. Recently my aircon has stopped working. I had it regassed today and they fitted a new filler valve. But still not working. Usually when I press the button I hear a clunk and the revs drop. I was hoping that refilling would sort the problem. The garage said their is no leak when pressure tested and thought it could be the compressor. Any ideas anyone?
Thanks Chris.
Berlingo 2004 2.0 hdi
Hi
There are two kinds of compressors that I know of , one type fitted to newer VWs, skodas etc don't have a clutch and don't "clunk" when operated and one which has
I don't have AC on my berlingo so don't know which is yours but if yours usually clunks then it must have a clutch, this clutch when disengaged stops the compressor spinning and saves wear and tear on the drive belts etc, when the AC is not wanted. This clutch sits on the compressor at the belt end and has a wire going in which works it. Worthwhile checking this wire is not damaged and check the fuses, the f 11 cabin fuse box and/or  fuse D under the BSI (on mine anyway).
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
OBD Red discussion
Yesterday 08:29 PM
» Replies: 32
2012 1.6HDI throttle position sensor
Last Post: mtd247
Yesterday 07:58 PM
advise please
Last Post: tricky2
Yesterday 06:43 PM
Central Locking, Is it aftermarket or stock?
Yesterday 04:41 PM
2nd Eolys tank, still showing risk of particle f...
Last Post: hofhomer
Yesterday 03:34 PM
Limp Mode - Low Power
Yesterday 09:51 AM
» Replies: 27
Top clock screen upgrade.
Yesterday 09:24 AM
Wire to tap into for DRL install
Last Post: Sahloul
03-12-2023 04:23 PM
How much adblue and where is it best to buy it
Last Post: dickl
03-12-2023 03:02 PM
Any opinions on Eolys .
Last Post: Pepito
03-12-2023 02:54 AM
