Power steering - is this normal?
I've just been to look at a 2002 DW8 1.9 van with only 80k on the clock. It's pretty tatty and will need several weekends of TLC but it has potential.
When I turned the steering wheel with the engine running, I found that if I gently held the wheel a few inches from its resting position (turning right or left) so the steering was just under tension, the wheel would gently 'twitch' (bounce) against my hand - as if the pump was engaging and disengaging cyclically.
Is this something to be concerned about or is it normal?
Many thanks.
Its the pressure relief valve in the hydraulics opening and shutting , nothing to worry about
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thanks very much.
Sent from my Moto G using Tapatalk
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
