  • 19 Vote(s) - 2.26 Average
WANTED: Instrument Cluster to fit 2001 Citroen Berlingo Multispace
X REG Citroen Berlingo Multispace Forte (Estate) full Instrument Cluster?
mark
any one got one for sale they seem quite expensive on ebay? anything under £30 with postage or collection west midlands area.
mechnic not sure it fix the random speed rev problem but worth a go if get one cheap enough.
Did you know that they can be repaired, because they have to re coded for your car specifically. Had same problem on mine 2 years back now.
Was quoted £1k + another £500 labour as it takes 3 hours to fit.
Went to an auto electrics place that I knew had a good rep from others who'd used it and they stripped out the dash cluster and sent it off and it cost me with all labour etc £245. Only problem now is that fuel gauge sender and temp sender do not give true readings, but for a car this age X reg I'll not spend anymore than is nec to keep it working. Still passes its MOT. Which is due on Dec 16th. Tis a common problem with French cars or so I was told.
(29-10-2011, 07:50 PM)horseunderwater Wrote:  Did you know that they can be repaired, because they have to re coded for your car specifically. Had same problem on mine 2 years back now.
£245 to repair it, and it still doesn't work properly? :whistle:
the code on the front of instrument cluster is m49/12meb.ja , does that mean its a popular one?
is it going to be hard to find a matching one?
i was told the code wrong it actually m49/12me8-ja
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
