Addressing the Blind Spot
Threads: 23
Thanks Received: 28 in 22 posts
Thanks Given: 60
8
Hi.
I have not had my van long (2015 Enterprise), and loving the practicality of the whole experience. (I should have bought a van years ago)
After driving for almost forty years its hard not to glance in the rear-view mirror, which of course I no longer have
and visually getting in and out of my driveway can be a little precarious at times (although I'm gradually getting used to it)
I have seen small Blind Spot, stick on mirrors for sale in Halfrauds and the Bay of Fleas, which apparently, you apply to a corner of your existing wing mirrors and they are supposed to give you a better field of vision.
Has anyone ever fitted these, and if so what are your honest opinions on them
Regards
C
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
Thanks Received: 7 in 5 posts
Thanks Given: 1
On several sites, such as Amazon, Geek, Wish, AliExpress, you can order a set with backup camera and a small screen. Just connect it to jour reverse light and have vieuw when you back up of connect it to 12V after igniton and have vieuw al the time you drive.
The following 1 user says Thank You to berreke for this post:1 user says Thank You to berreke for this post
• BigC
Threads: 23
Thanks Given: 60
8
On above advice
I kind of like the look of this camera number plate kit idea albeit I dont have a rear view mirror lol
but to function properly it needs to be central and that is not possible
I dont really want to see an out of place camera block but rather something that blends in
Threads: 20
Thanks Given: 7
14
It's easy enough to fit the rear view mirror. Just look at the screen when you're reversing so it works like a mirror!
You will find after time that using just the driver and passenger mirror will get easier. I don't tend to use the rear view mirror in our car anymore.
The following 1 user says Thank You to Tree for this post:1 user says Thank You to Tree for this post
• BigC
Threads: 20
Thanks Given: 2,126
18
I've had the little wide angle mirrors for years.They are very good for seeing what's coming down slip roads etc.My latest ones came from Wilkinsons(Wilky) for £2 a pair.At that price you can afford to try them but I believe they would be more use for a van than my Multispace.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• BigC
Thanks Given: 1
You can buy in kit or seperatly. You don't need rearvieuw miror to instal, they have al sorts of screens. The camera doesn't need to be centered to give good vieuw. Mine is at least 20 cm of and works fine. Wide angle lens.
Threads: 23
Thanks Given: 60
8
(30-04-2017, 09:59 AM)berreke Wrote: You can buy in kit or seperatly. You don't need rearvieuw miror to instal, they have al sorts of screens. The camera doesn't need to be centered to give good vieuw. Mine is at least 20 cm of and works fine. Wide angle lens.
Looking at this for now..cheap enough until I decide what visuals I would like up front...Thanks Guys some great replies there.
Licence Plate Camera
Threads: 27
Thanks Given: 20
13
You do get used to it after a while. When I first had a transit van it frightened the life out of me, but after a while I could reverse park into spaces that some Mini owners wouldn't attempt.
The following 1 user says Thank You to Solent for this post:1 user says Thank You to Solent for this post
• BigC
Threads: 23
Thanks Given: 46
5
(29-04-2017, 04:06 PM)BigC Wrote: Hi.
Regards
C
I used to use the type your asking about, size around 1" by 1.5" mind you it was many years ago. I found them ok. They are cheap enough to get a set to try and fixing them with blu-tack or similar would give you a good idea if they would suit you before p ermanently fixing them.
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• BigC
Threads: 23
Thanks Given: 60
8
I may try out the little 2" frame-less mirrors first (cheap option) and possibly go all out for a camera at a later date...Great help guys..very much appreciated.
C
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
