Air Bag Light
Hi Folks,
I've recently purchased my 2nd Berlingo, another Mk1 on an 02 plate, one problem i can't solve is, The Airbag Light does not light up at all, I know it should light up when you turn ignition on, & then go off after appx 5 seconds, but nothing happens at all, i've checked the wiring under the seat & all seems ok, has anyone had this problem before ? Any information greatly appreciated.
Mk1, 1.9D, Admiral Blue, 51 Plate.
You could try disconnecting the battery , with ignition off/engine not running, and leave for a couple of minutes before re-connecting and see if anything re-sets? If there is a passenger airbag that disables with your key, you could try disabling it, as the light should then be permanently on when the ignition is on, which, if it does come on, might at least show that the light itself is OK.
Hi Oily Rag,
thanks so much for your reply, I shall try what you said & let you know the outcome,
Might be worth not sitting behind the airbag when you first switch the ignition on, just in case.........!
Good luck!
Hi there,
I've no passenger airbag, I tried what you said with the battery, but still no different,
thanks anyway, I'll keep picking me brain, I have got another airbag which I kept from my previous Mk1,
I'll give that a try tomorrow, & try to elliminate each part,
thanks mate, i'll let you know, i( if i've got any teeth left),  LOL .
could just be a duff bulb
No bulbs in this instrument cloister.
Haven't tried changing airbag yet,
Will let you know when, thanks for your replys.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
