Threads: 27
Thanks Received: 345 in 303 posts
Thanks Given: 50
17
I have a problem with the light board on my little trailer and I was sitting in the boot trying to sort it (failed miserably I think the wire to the right indicator has a break in it) But I digress, I went and sat in the driver's seat and switched the ignition on and the display lit up with the message "COFFRE OUVERTE". In between plugging the light board in and checking it then swapping a couple of bulbs and switching it on again it had somehow changed back to its own native language. Could it be something to do with Brexit ?
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post
• ron
Threads: 41
Thanks Received: 63 in 58 posts
Thanks Given: 107
Definitely a Brexit problem, could cost anywhere between £50bn and £100bn to sort out.
Matt
2016 Multispace XTR BlueHDi 100 S/S Gris Artense Met
The following 1 user says Thank You to Matt Haigh for this post:1 user says Thank You to Matt Haigh for this post
• ron
Threads: 6
Thanks Received: 23 in 21 posts
it must have heard that drunkers pratt wittering about english being a dead language, on the tv news at lunchtime
The following 1 user says Thank You to ricc for this post:1 user says Thank You to ricc for this post
• ron
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
14
I have no idea on the French problem however i did have a ZX once and when i connected to my trailer it locked the doors on me! That was fun :D
