Seat cleaner
Hi all, looking for some advice on a suitable seat cleaning product, ive noticed a few water mark style stains on my seats. Can anyone recommend a decent cleaner ?
Any good upholstery cleaner will do.I've got a spray can of Turtle Wax cleaner that I've had for years & is very good.It's a foam type & easy to use.
Hi,
Tesco Upholstery Cleaner - about £2 for a good size can of foaming spray. I use it for everything as it lifts muck out in the foam as it froths up. Things like carb. cleaning, if you can remember carbs... clean out with petrol & brush, then spray on Mr Tescos finest. I then use compressed air or you can stick it under the tap to remove the residue, to get superb results.
  • noyasystem
I dont really like Halfrauds but sometimes needs must...On my old 1 Series BMW the upholstery marked up very easily even rain spots would cause a mark...I found this product, applied correctly worked the best for me...I am an avid car detailer in my spare time and I'm always trying new products...check this out, its only cheap and it comes with its own applicator brush
Give it a try for a fiver
Turtle Wax Interior 1
Regards
C
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
I also use a vax does a great job, first I scrub at stained area with a nail brush
And hot soapy water then use the vax and seats end up damp and will be dry in no time
2012 XTR Berlingo 1.6 hdi e semi auto wicked red
2016 Nissan Qashqai 1.5 Tekna manual Ink Blue
[-] The following 1 user says Thank You to Iank for this post:
  • noyasystem
Go for Tesco Upholstery Cleaner as oilyrag mentioned out. I use the same.
I've had my eye on this for a while as my work van needs doing as well, anyone use one ?
Look at this on eBay http://www.ebay.co.uk/itm/351667514971
Mark
Sent from my Vodafone Smart ultra 6 using Tapatalk
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
