Hi
Hi All,
I've got hold of a 2002  (october) 1.9D. Berlingo Needs some work :-)
First thing is to identify the engine, and model , so I can go to the correct discussions, er...any help on that graciously received...
I think I've a DW8 (?) , I took the plastic cover off for the photo below,  and it sounds like there are three versions WJZ, WJY and later WJY (?) though the Haynes manual is a bit difficult to understand. My VIN number does have WJY embedded in it so that's a clue I hope.
Any clues to where I can find the idle speed sensor also appreciated (currently it's at 1050rpm all the time), then I need to see why the alternator light is only going off once it's revved high for a while (charged the battery and that seems to have held at 12.5, but when I start the engine voltage drops to 11.8v and only rises slightly on revving)... ant THEN I can try and figure out why the fuel guage needle appears to be around 90 degrees too far clockwise.... though at least it works :-) )
Plenty to keep e occupied.
Cheers,
[Image: 20170507_200220_zpscq8dehmt.jpg]
Hello keebab and welcome to the forum. Are you the Döner or Yufka variety (just jokin')
[-] The following 1 user says Thank You to 3rensho for this post:
  • keeebab
Cheers,
Hi and welcome
  • keeebab
Hi and welcome
[-] The following 1 user says Thank You to stlords123 for this post:
  • keeebab
Last Post: TGD
Today 09:50 PM
Today 12:29 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
