New member hear
Hi everyone ,thanks for letting me join , i am having serious trouble with my citroen , i have been on  nearly all the forums to get help, i was told the berlingo forum was the best chance i have ,regards Edward
Hi Edward and welcome.
Hi Edward and welcome to the forum. Yes, you are definitely in the right place for advice and tips.
Hi Ed and welcome
Howdy, welcome , your definitely in the right place, this is a wonderful forum with lots of really helpful people, there's a whole lot of mileage driven on berlingos between us all.
(10-05-2017, 02:47 AM)3rensho Wrote:  Hi Edward and welcome.
Thanks for the welcome, I hope you
guys can help me out, I am a Citroen
Owner, i have the STOP light come
on the dashboard, and it says oil
pressure to low, I have taken it to
four garages, to date it has had ,
a new oil filter
a new oil sensor switch
an oil change w5-30 fully synthetic oil
the sum removed and cleaned also the sieve
a manual oil gauge test
the turbo tested
a new oil pump, all parts were purchased from
Citroen , but still have the problem, please if
anyone can help me please let me know,
The oil level is spot on , no leeks, thanks
 Regards Edward
(10-05-2017, 02:47 AM)C3rensho Wrote:  Hi Edward and welcome.
a new oil filter
the turbo tested
 Regards Edward
(10-05-2017, 10:58 AM)connorsky64 Wrote:  Thanks for the welcome, I hope you guys can help me out, I am a Citroen Owner, i have the STOP light come
on the dashboard, and it says oil pressure to low, I have taken it to four garages, to date it has had ,
  • a new oil filter
  • a new oil sensor switch
  • an oil change w5-30 fully synthetic oil
  • the sum removed and cleaned also the sieve
  • a manual oil gauge test
  • the turbo tested
  • a new oil pump,
all parts were purchased from Citroen , but still have the problem, please if anyone can help me please let me know,  The oil level is spot on , no leeks, thanks   Regards Edward
Check the brake fluid is well topped up. On mine it's very sensitive, STOP came on intermittently until topped up. Wouldn't explain a low oil pressure warning, mind.
Are you sure its a low oil pressure warning and not a low oil level warning?
Why have all that work done if the garage test gauge says you have pressure? I take it the garage gave you the okay re the pressure or did they say you Do have low oil pressure?
Hi Polar, all they said was change the oil again after 2 months, i drove away after paying
them £245.00 i got three parts of the way home and the light came on again , i phoned the garage back up they said it must be an electrical fault now, they said bring it back but it would cost more as it is a different fault, a friend of mine who owns a balingo van told me
to join this site, he said it did not matter about me not having a balingo , a citroen is a citroen and if they can help you they will, i just don't know what to do anymore, my wife has called me some things i never new she new such words, but i must agree with her ,the ebay seller has had me over good and propper
triangle light
Last Post: norm1
Today 12:20 PM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
