Threads: 29
Thanks Received: 3 in 2 posts
Thanks Given: 58
I've read that its every 50'000 miles for the fuel and air filter ? Can anyone confirm that ?
I have a B9 1.6 diesel , currently 81'000 miles done at the moment.
Threads: 20
Thanks Given: 2,126
18
I change mine @ 25,000 miles just to be on the safe side.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• michaelg
Threads: 7
Thanks Received: 27 in 25 posts
i would go on a site you put the reg in and they tell you but be careful on the fuel filter as they sent my mechanic wrong 1 fuel filter is ether on back left of engine as you look at it or on the right hand side of the block
Threads: 22
Thanks Received: 13 in 11 posts
Thanks Given: 24
Wow !
I'm surprised, where did you get this info ?
I'm obviously different in oppinions on how often to change the filters, for example, I change my Air Filter every Five Thousand Miles, they only cost average £7, & help your fuel consumption so much, easy to change & save you £ss in fuel, as for the Fuel Filter, change it every year, no matter what mileage you have done, or if Twelve Thousand miles comes sooner, change it then, filters don't cost much, & are beneficial all round, I also change my Oil every Five Thousand miles & Oil Filter alternatively at Ten Thousand.
Hope this helps.
Mk1, 1.9D, Admiral Blue, 51 Plate.
Threads: 9
Thanks Given: 316
15
Air filters can go far more milage than you are changing them at - you will find no fuel benefit unless driving in very dusty conditions.
Fuel filters are 3 years or 36K no real benefit form over changing them also.
If you are changing your oil without the filter you are making a big mistake.
But whatever keeps us happy.
Threads: 9
Thanks Received: 26 in 21 posts
Thanks Given: 19
I change all my oil and filters once a year if the thing passes it's MOT. It gets a full service as a reward. The parts are so cheap it makes no sense to skimp.
Sent from my SM-G925F using Tapatalk
The following 1 user says Thank You to Growler73 for this post:1 user says Thank You to Growler73 for this post
• ron
Threads: 22
Thanks Given: 24
What was I thinking of ?
you're right Polar, I do change Oil Filter every time I change the Oil,
The reason I change the Fuel Filter every year is I get a build up of water in the housing.
The following 1 user says Thank You to THE BADGE for this post:1 user says Thank You to THE BADGE for this post
• polar
Threads: 16
Thanks Received: 54 in 17 posts
Thanks Given: 4
8
Changing the Diesel filter on my 2012 XTR is not a easy job ( not as easy as on a VW golf) I bought one while on speical offer with the view to changing it myself but gave up when looked what was invovled in the Workshop manual
