Exhaust Spring Bolt parts
Threads: 2
Thanks Given: 4
Hi, new to the forum, so apologies up front if I sound a bit of a numpty.
First time assembling new Cat and centre pipe on exhaust on a 2005 Berlingo. When I bought the bolt spring fitting kit which came with the cat, there was a couple of parts missing. I'm not sure what these are called, but see some refer to them as 'top hat' washers. They go on the bolt head and reduces the hole on the cat flange before the spring/.
Please can anyone tell me the 'official name' for these two 'top hats' and if they can be bought separate anywhere (correct size). Thank you for any help.
Threads: 2
Thanks Given: 4
There were two of these in the old cat flange, but so rusty, I wasn't able to get them out. Really need to know what to call them, so I can get a pair as it is holding up re-assembly.
Threads: 4
Thanks Received: 135 in 131 posts
Thanks Given: 3
13
Can you not order a new clamp and send the dodgy one back, or call into a Quickfit type of exhaust centre and match up what you have? They are pretty specific in size and you're unlikely to find them off the shelf in an ironmongers, or for sale separately.
Threads: 43
Thanks Received: 67 in 56 posts
Thanks Given: 9
9
http://i.imgur.com/PWnl3R1.jpg
They look different to what you normally get but as photo above shows your typical set, it's simply a washer shaped to hold the spring in place. If these are any good to you I can sell you a set for 4.50gbp , basically x2 bolts with washers and springs in high strength steel
Threads: 2
Thanks Given: 4
(25-05-2017, 03:33 PM)oilyrag Wrote: Can you not order a new clamp and send the dodgy one back, or call into a Quickfit type of exhaust centre and match up what you have? They are pretty specific in size and you're unlikely to find them off the shelf in an ironmongers, or for sale separately.
Hi oilyrag, can't really send anything back as I have opened the fitting kit and the company I bought it from says they can't accept opened items! How are you supposed to check all is there? Was on the phone to them this afternoon, they said they would look into this for me, but haven't got back yet. I'm not holding my breath. Anyway, we have a local garage, not sure if they would be willing to help by just selling me a couple of these, but I could give it a go.
Thanks for the suggestions mate
Threads: 2
Thanks Given: 4
(25-05-2017, 04:05 PM)Kokain Wrote: http://i.imgur.com/PWnl3R1.jpg
Hi Kokain, -your photo shows exactly what I have in the kit, so maybe I don't need those 'top hat' thingys. But, the confusion I have is I can't see how the spring can work without them. With the set up in your photo, wouldn't the bolt just pass straight through the hole in the cat end flange? If I set the bolt up as in your picture (and you are right as I have seen it elsewhere on the net looking like that) the spring just seems to be loose between the bolt head and the shaped washer which goes over the thread, but not any higher up the smooth part of the bolt. Maybe I'm not seeing something obvious?
Threads: 2
Thanks Given: 4
25-05-2017, 04:41 PM
(This post was last modified: 25-05-2017, 04:50 PM by sharleko.)
Would this be the right set up Kokain: Bolt and spring (on bolt) through cat flange, through middle section pipe flange, then the washer and finally small nut. (so the spring is between the bolt head and the cat flange) and rest of bolt goes through the middle section pipe flange). That's the only way i can see there being any way to be able to compress the spring. I still can't see how the bolt head won't pass through the hole of the cat flange though as the holes seem too big?
This is what I have with the kit, the same as your photo Kokain:
Threads: 43
Thanks Given: 9
9
25-05-2017, 09:44 PM
(This post was last modified: 25-05-2017, 09:51 PM by Kokain.)
The following 1 user says Thank You to Kokain for this post:1 user says Thank You to Kokain for this post
• sharleko
Threads: 2
Thanks Given: 4
Thank you for all your help mate  Yes, think I'll just stick a washer on them and see how that goes. I think your right about the welded in flange washers, that is what i could see on the old cat pipe and thought was missing from the kit. Thanks for all the photo's -they are a great help as I am fairly new to this. I used to do a bit of bike mechanics years ago, but not worked on cars for a while. Cheers
Hello!
Last Post: jackusa455
Today 05:16 AM
Rear Tyre wear
Yesterday 10:58 PM
Last Post: Grizz
Yesterday 08:09 PM
» Replies: 1952
A bargain Rival Dacia Jogger 7 seater
Last Post: ComboLifer
Yesterday 07:44 PM
Brake Pads
Yesterday 07:42 PM
Help
Last Post: Longerjohn
Yesterday 07:26 PM
Insulating under inner trim
Last Post: Jib24
Yesterday 05:12 PM
Gearbox
Last Post: benoliver999
Yesterday 02:02 PM
Rear panel of dash glove box removal
Last Post: Zion
Yesterday 12:06 PM
Protective Cover Extenso Cab
Last Post: cancunia
Yesterday 07:13 AM
