Threads: 29
Thanks Received: 3 in 2 posts
Thanks Given: 58
29-05-2017, 11:55 AM
(This post was last modified: 29-05-2017, 12:43 PM by michaelg.)
Interesting,
I wonder if it would pick up much remaining oil say after the oil has first been drained from the sump hole.
Hate to run a battery flat though.
Threads: 5
Thanks Given: 4
21
It only runs for a couple of minutes, so no battery issues. In France there are self service oil change points near supermarkets where you put a tube into the dipstick hole and pay a few Euro and it sucks the old oil out and disposes of it. In some ways it would be better to add a piece of metal brake pipe tubing to the flexi so that it hits the bottom of the sump and pulls out as much as possible, but that said the flexi is likely to lay flat and only a mm or two of oil will be left, even less if you park the vehicle on a slope to get the remaining puddle under the dipstick hole.
The end of my dipstick is in the sump somewhere, after the plastic bit that shows how much oil is there fell off - typical Citroen - they appear to become more and more reliable as time goes on as most of the dodgy bits have fallen off during the first few years.
I guess a way to check the efficiency is to put a piece of wire into the sump through the dipstick hole and see what depth is left after normal sump draining via the plug, and then see if you can get any more out with the pump.
Threads: 15
Thanks Received: 28 in 17 posts
Thanks Given: 11
I've used a Lidl pump for a couple of years now, and I'm convinced that it removes more oil than can be drained through the sump plug, because of that recess. You can manoeuvre the pipe when it's in the sump to make sure you leave the minimum residue of oil. Also handy for sucking out the remaining oil in the filter mount and cover. It makes the whole job a lot cleaner, quicker and easier, well worth the £12 the pump cost.
Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
31-05-2017, 07:54 AM
(This post was last modified: 31-05-2017, 07:55 AM by V6BOY.)
In these 1.6 HDI you will be getting more oil out by suction,I have both an electric pump and a manual one much prefer the manual one.
