03-06-2017, 04:26 PM
Hi, I'm new here having just bought a 54 plate Berlingo Multispace Forte, 2.0 HDI. My last couple of cars have been estates so trying something new with this car.
It was a cheap buy and has a few issues that may need attention, but I'm going into it knowingly.
The main thing is a slight crunch going into 3rd, which seems to be not unheard of and likely to be the synchromesh wearing. I guess eventually this will result in the box needing replacing/rebuilding, but it could be 5 years away (longer than I'll have the car most likely) or 5 months away, and that's a risk I'm taking. My plan is to change the gearbox oil for something thicker/better (need to do some research) to mitigate it. I also wonder if I could flush it through with something (cheap gearbox oil?) to remove any debris?
Two years ago it had two new rear tyres and a reconditioned rear axle last year. The nearside rear tyre is worn badly on the inside, but not the outside. What would cause that on a rear tyre?
Cheers
Cheers
