MAP air pressure sensor
Can anyone tell me what they have or want should be the return voltage on this sensor for 1.6 hdi. I am reading 2.39v at idle. Does seem high as I thought the range should be 1 - 5v.
I'm no guru but I'd expect idle to be around 1.5 / 1.6 volts and WOT to be around 4.2 / 4.5 volts
Hopefully someone will have the definitive data for you.
Here is the test procedure: https://www.berlingoforum.com/thread-102...ure+sensor
If your Lexia is showing MAP error then you need to replace it.
Best regards,
brajomobil
Users browsing this thread: 2 Guest(s)
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
